i have polk rti10's as my mains, polk csi3 center, jamo bipolar surrounds, and polk rt15 backs. which receiver between the onkyo and the pioneer elite would go best with these speakers? thanks, nolan
I agree, the Pioneer is superior to the Onkyo. Good choice and I am sure you will be quite happy with it
audiophilewanabeinhawaii
I have a problem. I've had my Pioneer Elite vst-54tx for a week now. Whenever i play my dvd, "Blade II", i have heard some distortion coming from my rear speakers at certain spots during the movie. It hasn't happened so far with any other dvd. The dvd is fine, because my friend played it on his system with no problem. It seems to happen at all volume levels. The crossover is set to 80hz, but the specs for the rears say that it can handle up to 60hz. I've also heard the distortion from some of the other speakers but have not pinpointed which ones. Does anyone have any clues about this problem?
Not all dvds will play on all players.Since you have not had a problem on any other dvd I suspect that dvd and your player are not getting along well. Clean the dvd and try again.
Elitefan1, you were right. the problem wasn't my receiver or speakers. when i turned my receiver off and just played the dvd with the audio from my tv speakers, i could still hear the annoying static noise. it's a compatability problem between my sony dvp-ns425p dvd player and the movie. anyone with suggestions for a dvd player that can play both dvd+r's and sacd's for preferably under $150.
