New member Username: Sigma6Post Number: 1 Registered: Oct-04 | Hi, I have a BOSE Lifestyle 8 system and I am thinking about buying a SACD/DVD-A player. My question is, I know I won't be able to play these formats in 5.1, but will I still be able to play these formats through my BOSE and receive a high resolution sound (and I am thinking about buying a low end player for now, eg. the pioneer DV-676A)? Cheers, Ben. |
Silver Member Username: Arnold_layneMadridSpain Post Number: 173 Registered: Jun-04 | It depends on the interconnections. S/PDIF (coaxial or optical) cannot handle SACD or DVD-A bitstreams. How have you hooked up your system? |
New member Username: Sigma6Post Number: 2 Registered: Oct-04 | Well I was thinking if I did buy a player I would put it through the coaxial input, but that doesn't seem like a good idea now ![]() |
Gold Member Username: John_aPost Number: 2293 Registered: Dec-03 | Benjamin, You should still get higher resolution sound than from CD. Many SACD and DVD-A discs carry a two-channel, stereo mix. And, if not, players will often downmix 5.1 to stereo. So there should be no discs you cannot play. The thing to do would be to take the player's 5.1 analogue ouputs for Left and Right main channels, and connect those to any "Aux" input, just as you would for an external CD player. I think you will be impressed at the sound quality. The same goes for DVD-Video discs; many carry a high-resolution stereo track, too. Some people prefer that to 5.1, for music on DVD-V. |
Unregistered guest | I have a Lifestle 8 and the sound just quit on me today. I checked all the connections and reset the power. Any ideas anyone? |
