Having a strange problem with this remote, wondering if anyone else has experienced it...
I've got the remote programmed to control all of my components, and until today it's been working very well (I've had it a couple of weeks). Tonight, though, it began acting up. When I select a device using a key at the top, and then begin using other keys to control my components, it works only about 50% of the time. Then it freezes up for a few seconds, and reverts to controlling the receiver again. It's frustrating - I'll have to go dig up my old remotes again.
Every remote I have seen comes with "heavy duty" batteries and not the akaline etc. The HTR-2 remote is great but probably sucks battery life. Its the only remote my wife has been able to use and handles TiVo, the NAD, a DVD/CD player, the TV and a VCR. It is nice to have a single remote that can control everything. I had the same thing happen. The clue is when you press the DVD button (or whatever) and then the command and the AMP button lights up. That means: change the batteries.
To have the HTR-2 not suck so much battery, it is recommended to set the length of the "light-up" period short. Two seconds is default, 0 will disable it completely.
