Setting up my new Onkyo TX-SR701. Very simple config. so far, just front left and right speakers and nothing else attached. However, when i go into speaker configuration under the setup function, the second choice (according to the manual) should be Front L/R and it does not appear. scrolls right from subwoofer to center. Thus, i am unable to get any sound from the unit, which was simply going to be fm radio to start.
If you tell the Onkyo that you have no sub, it defaults the Front L/R to Large and doesn't display the option. (Change sub to yes and you'll see the Fronts appear.)
This should not cause you to get no sound. When I first hooked up my 801, I thought I had a problem until I turned the volume up to 30-35.
