How do I format a CD-R ? Please Help!!!
I am trying to erase a CD by formatting it. I don't know of any software on my computer to format it. I have windows xp.
I tried right clicking on the C drive with the CD in it to see if "format" was an option. It wasn't. I don't know how to get the CD formatted.
Can anyone help me??? Any help would be greatly apprecaited.
i am trying to erase a CD by formatting it. I don't know of any software on my computer to format it. I have windows xp.
how are files on screen copied to cd? do i need a special program? is formatting required?
www.nero.com <<< you need that.
You wont need to format a blank cd
You CANT Format a CD-R..
If you download Nero.. and need more help
Contact me at
iavictor@tiscali.co.uk
I'm having the same problem. I can write data files to my CD-R, but then I can't delete them or update them. It says they are read only files. So is this just a function of CD-Rs, and not something I'm doing wrong? If I want to overwrite old data files on a CD, with updated files, or delete files all together, which type CD do I need to use?
i cant access my cd once its been written. i use nero and cd-r
How do I format a CD-R on my computer?
Guy who needs Help
You can not format a Cd-R you need to get a Rewritable Cd which will allow you to use it over and over again... Now what the crap does it mean by it could be using a format that is not compatble with windows (it's a Dvd-r)seeming as it worked on my cousins Pc? How can I access this Cd, it's got alot of stuff i need in there!
I would be very greatful if someone could help me out...
Contact me at Coolest_sam@hotmail.com...
Thanks
how do i format a cd -r on my computer?
Username: Idocanoe
Ely, MN US
Can I format a CD to play on my DVD player? The video I want to put on it is just 5 minutes.
Username: Username
in order to format the disk you will need to do the following:
wear latex gloves
put on safety goggles
wear protective clothing
prepare your funeral
take the disk and place in hand
throw the disk and destroy it
your welcome
Username: 696
You can not format nor delete any data of any kind on a cd-r (recordable cd) because the data is "melted" (burned) onto the cd-r so it cant be un-done. You need a cd-rw (rewrite-able) to "format" or delete the data stored.
-> http://en.wikipedia.org/wiki/Compact_Disc#Recordable_CD
-> http://en.wikipedia.org/wiki/Compact_Disc#ReWritable_CD
Need to Register?
Forgot Password?
Enable HTML code in message
