Unregistered guest | I am curious if I have to set the Speakers to Small on the T763 to get the Subs to work in Stereo mode via LFE Output, or can I set them to large and still get Sub. Also I saw that NAD was releasing V2.0 of the firmware, are they already past that? Will any NAD authorized dealer update me for free @ purchase time? Any help here would be great. |
Unregistered guest | I just saw a previous post sort of covering the software side. If I get a unit that is pre v.2 can I get it upgraded and will that include the improved bass options?...if so what are those options? If all I miss out on is DPLIIx then I don't really care. One other thing. I see no mention in any literature that the T763 supports DTS NEO Discreet 6.1 yet almost every reciever costing 1/3 less than it does support it, or says so clearly anyhow. It makes no mention of it that I can see, Is it really important? I am sounding like a total no0b but this will clear a few things up for me......sometimes you gotta get back down to the basics so you can get back on top. |
New member Username: KonoyaroSan Francisco, CA United States Post Number: 2 Registered: Jul-04 | Hmm, well the product info for the T763 on the NAD homepage mentions support for the following: Dolby Digital, Dolby Digital EX, Digital ProLogic IIx, ProLogic IIx, DTS, DTS ES, DTS NEO:6, Matrix 7.1, EARS, Enhanced Stereo Surround Modes DTS ES, which the T763 has, handles DTS 6.1 Matrix and DTS 6.1 Discrete decoding. |
Silver Member Username: LandrovalPost Number: 777 Registered: Feb-04 | The v2 will use the sub even if your speakers are set large, if you want to of course. |
TJ Guy Unregistered guest | Are you sure....often DTS ES and Discreet are mentioned seperately....I just want to be sure that DTS ES includes the Discreet 6.1 spec. It does not appear that the |
New member Username: KonoyaroSan Francisco, CA United States Post Number: 3 Registered: Jul-04 | You can find out about various DTS technologies here: http://www.dtsonline.com/technology/at-a-glance.php This spells out the features that DTS ES and other DTS variants provide. |
TJ Guy Unregistered guest | yeah I checked it out....it looks good. Thanks for the Info guys. I have settled on the T763 right now...I am doing an in home demo! |
