I don't have a lot of experience with recievers so I'm sure witch one to get. The H/K 630 is 699 on sale and the H/K DPR 2005 is 999 on sale. I have decent infinity speakers, and I use my home theater for 60% music 50% movies. My first system was a home theater in the box type deal so i dont know a lot about higher up recievers. Is the DPR 2005 worth the extra 300? Any thoughts or comment? Thanks
endora
If the HK630 is at 699$, go for it, this is an extremely good price for an excellent receiver!
For the price I'd go for the DPR2005. The AVR630 is nice too, but the 2005 is probably the better bang for the buck.
Also, the 630 is being replaced with the 635 this fall and has some substantial upgrades added to it. It won't be $699. The DPR2005 on the other hand will be unchanged and HK is promoting these new digital amps (thus the great price).
Depends what you want and how the 2005 sounds. If you can listen to both you really should do it. The best feature set is found on the AVR635, so it might be worth waiting for that.
