Hiding Cables under wall2wall Carpets
Username: Homedesign
Post Number: 32
How can this be done with installed wall-to-wall carpet? Is there a tool to send the cable from a small cut in the carpet at one end of a room to the other side of the room, for insance?
Username: Edison
Post Number: 290
You can get flat cables that doesn't show up as much, and run it along the wall if you really want to hide it.
www.accessories4less.com has ixos flat cable.
