New member Username: Jake272727Vernal, Ut Usa Post Number: 1 Registered: Sep-04 | Im starting with any suggestions and help you might give me so far this is what im leaning toward. SVS PB2-ISD for my sub, hk AVR 430, for my reciever and Fluance sx-htb for my suround costing me about 1700 total please help me to make sure i dont make a huge mistake thanks. |
New member Username: Jake272727Vernal, Ut Usa Post Number: 2 Registered: Sep-04 | also i was wondering if im really getting all my bang for my buck such as is the reciever very good or should i get something better i have about 2 grand to spend on the whole system. |
Gold Member Username: Project6Post Number: 1592 Registered: Dec-03 | Not a bad start, nice sub, too. Why such a big budget on the sub? Totally disproportionate to the Surround speakers? |
New member Username: Jake272727Vernal, Ut Usa Post Number: 4 Registered: Sep-04 | well i love the base at the movies and i really could not find any good reviews on any surround sound speakers and all i could find on recievers is everyone likes the one they got i never hear the negetives id like even a thx reciever but again i dont know what really would sound good. |
New member Username: Jake272727Vernal, Ut Usa Post Number: 5 Registered: Sep-04 | also ive seen nothing but good reviews about the fluance speakers. |
New member Username: Jake272727Vernal, Ut Usa Post Number: 6 Registered: Sep-04 | i also like this reciever Harman Kardon AVR 630 |
Gold Member Username: Project6Post Number: 1597 Registered: Dec-03 | Looks like you have it all figured out and you seem to know what you want. Have you checked out the set up from Ascend Acoustics, using the CBM 170s for all surrounds and an HSU subwoofer? http://www.ascendacoustics.com/pages/products/speakers/cbm170/cbm170.html they are also selling the HK for a discount, so check them out if you can save a few bucks. |
Bronze Member Username: HokievtPost Number: 39 Registered: Aug-04 | I have the SX-HTB's and I would think you could get a better speaker for $1700. |
Silver Member Username: Rh1Post Number: 172 Registered: Jun-04 | Check out Tannoy fusion speakers, this will fit quite nicely in your budget. These speakers are excellent for this price and would match nicely with you H/K receiver. I listened to them yesterday on the H/K 330. Very detailed throughout http://shop4.outpost.com/product/4185153 |
New member Username: Jake272727Vernal, Ut Usa Post Number: 8 Registered: Sep-04 | ok tell me me what u think on these. Harman Kardon AVR 630 or should i get a yamaha or is there something better in my 2000 dollar budget i should get. |
New member Username: Jake272727Vernal, Ut Usa Post Number: 10 Registered: Sep-04 | SVS PB2-ISD or an hsu sub i could buy two hsu vtf-2 for less money but i dont know if it would sound as good. |
Bronze Member Username: Jake272727Vernal, Ut Usa Post Number: 12 Registered: Sep-04 | SVS PB2-ISD or an hsu sub i could buy two hsu vtf-2 for less money but i dont know if it would sound as good. I like those surround speakers u mentioned but would i be be better off getting the system or just buy indavidualy. |
Silver Member Username: Rh1Post Number: 173 Registered: Jun-04 | I would definately go with the H/K receiver over Yamaha. I would agree that you should spend a little less of your budget on the sub than what you have in mind. Even if you like a lot of bass. I would stick to something like $1000 for speakers, $600 receiver, and $400 sub. This would give you what you desire. You could certainly get enough sub with $400 by shopping around. Why not the Svs pb10-isd? |
Silver Member Username: Rh1Post Number: 174 Registered: Jun-04 | You could also try the Earthquake JR, I think those run about $500 |
Silver Member Username: LandrovalPost Number: 762 Registered: Feb-04 | I agree with vols. 1000/400/600 sounds like an ok budget balance. Although I would still put a little more to the speakers. |
