Looking to buy Home Theater Speakers will spend 5-6K ...
Porscheman
for the center, 2 fronts, and 2 rears i have 2 veloydyne subs fs 15 from 6 years ago should i replace and suggestions thanks....have been told to look at Klipsch Reference series (rf,rc,rs 7's) Monitor Audio ref series 60 with matching center and rears...suggestions
thanks
Username: Edison
Post Number: 292
You can use Veloydyne subs - they sound decent. What receiver will you be mating them with? In what ways are you not satisfied with the present system?
There are many good speakers at the price point. Try to hear these, and see which one you like the best.
Paradigm
PSB
Rocket http://www.audiorevolution.com/equip/rocket_speakers/
www.ascendacoustics.com
Some people really like Klipsch, and others don't. I like monitor audion better than Klipsch.
