Down to three recievers Pioneer Elite VSX-52TX Denon AVR-2803S Yamaha RX-V750 Really thinking of going with the Pioneer Elite but still undecided need some help.
More information will help people determine a worthy reply
Like what speakers you'll be using. Room size Floor and furniture type (soft, hard etc) Percentage of use for music or movies. And what brand of popcorn do you eat :-)
I'm not familiar with the speakers. If you consider them to be on the bright side (more high end than low end) then I'd go with the Elite. If you consider them warm go with the Denon. The Yamaha would be way down on my list but, for warm speakers in your listening environment, maybe not bad for movies. Hope that helps.
