| KLH Subwoofers | neal m | 4 | |
| Definitive Technology Supercube Reference? | Al Holland | 5 | |
| Need Advice-Paradigm Subs | Anonymous | 11 | |
| Multichannel means no LFE Sub track? | KEGGER | 3 | |
| OHM LOAD HELP | Peter Galbraith | 2 | |
| Help Me Decide | neal m | 14 | |
| The difference. | Peter Galbraith | 2 | |
| Klipsch RW-8 or Canton AS 20 ? | Anonymous | 3 | |
| Hmmmmm sound in subwoofer.. | KEGGER | 2 | |
| Hsu stf-1 versus stf-2 - worth the $100? | Don Kelly | 1 | |
| Is polk psw202subwoofer correct for my room size and av receiver | shank | 3 | |
| Problem with Rear R output | Eric Pisanko | 2 | |
| Any web for learning the placement of sub......... | J. Vigne | 2 | |
| Rca 125 watt sub | Eric Pisanko | 1 | |
| I like rock, what kind of systme is best for it? | likes rock | 1 | |
| How to connect my RCA Input Sub to my Receiver!! | Skial123 | 5 | |
| Connecting subwoofer to "digital ready" amp | Brian Goldschmidt | 1 | |
| Velodyne CHT-8 cutting in and out | Steve D | 1 | |
| Sub set up | cornboy | 1 | |
| Klipsch RW-8 or Canton AS 20 ? | Anonymous | 1 | |
| I NEED HELP | fletcherreede | 6 | |
| Subwoofer placement... | suresh babu | 1 | |
| Help me choose sub: PS1000, ASW100, or Better?? | Anonymous | 3 | |
| Venturer av100 sub upgrade? | Lester Ferguson | 2 | |
| Using 5 ohms 250watts sub.with 100 watts 8 ohms receiver. | suresh babu | 4 | |
| Sub placement debunked | Stan Bodnar | 2 | |
| Power problem in sub.. | suresh babu | 5 | |
| Sub recommendations | My Rantz | 2 | |
| Help! Can't extract toy-blocks from subwoofer | KEGGER | 2 | |
| JBL E250P subwoofer | Anonymous | 2 | |
| Passive Subs- aside from SVS, any others out there? | Brock Frederickson | 1 | |
| Buzzy subwoofer replacement speaker | dwsw | 4 | |
| Trying to find a speaker box | Grizzly | 2 | |
| Sony Subwoofer | Kyle Berg | 5 | |
| Energy ES8 replace or not? | newbie | 4 | |
| Home Subwoofer LFE vs Line in hockups??? | Gregor | 5 | |
| Insufficient cable connection to subwoofer | david stier | 1 | |
| Kenwood sub | mak203 | 1 | |
| Problem | Joseph Martin | 3 | |
| Looking for powered sub | albaro | 3 | |
| Lookin' for a Sub | Jimvm | 12 | |
| Problem | Joseph Martin | 1 | |
| Equalizer?? | Dan Reid | 1 | |
| Mirage BPS400 Dual 12" Subwoofer | power-ranger | 4 | |
| Subwoofer Connections | Tom V. | 2 | |
| Subwoofer at fault? | Tom V. | 12 | |
| Converting subs for PC use | Red Rick | 3 | |
| Subs - Boxed, Ported or Inverted??? | Neal | 6 | |
| HMMM FLUANCE? | Matt Haug | 3 | |
| B&W DM601 s3 + SUB or DM 602 s3 ?? | Gregor | 3 | |
| Would you please let me know if this passive subwoofer with this co... | Sundeep V Menon | 1 | |
| Any opinions on Yamaha YSW-215?/ ADVICE on SUB under $300?? | Marko Stijelja | 1 | |
| Are the Atlantic Tech Subs worth getting | kingtut | 2 | |
| Crazy Talk! Random skreetch from RCA Sub | Erik Mayo | 1 | |
| NHT Subs | Berny | 3 | |
| Volfenhag 12" | ryan knoll | 2 | |
| Help with Subwoofers and Amps | Leelan | 6 | |
| Velodyne CHT-10 vs. Hsu STF-1 | Mr. Speeed | 7 | |
| 1 big sub? or 2 small subs | eric belanger | 3 | |
| Adire Tempest with 2 15" PR or 2 4" ports | JeffKnob | 1 | |
| Buzzing subwoofer | nick anderson | 4 | |
| Self-Powered Subwoofer vs Non-Powered (Passive ?) Subwoofer | KEGGER | 5 | |
| Any reccomendations for subs under 7? | Sumguy | 1 | |
| I have everything you are looking for for great prices!!!! | Berny | 2 | |
| W7 need a tip | Anonymous | 2 | |
| Mainstream subs? | Anonymous | 3 | |
| Mysterious Subwoofer Dilema | jack belton | 2 | |
| Active sub to car amp? | jack belton | 1 | |
| James Subwoofers | Jackson5 | 1 | |
| Best sub for under $700 | Brandon Konran | 4 | |
| Subwoofers | Brandon Konran | 3 | |
| Rel stygian? | mark goves | 13 | |
| Best small sub??? | huntergriffin | 26 | |
| New car wnat lound and SQ system | sdfjkop | 4 | |
| Athena asp400? or better for same $ | toto fabella | 3 | |
| What can I buy for 300 dollars without going to ebay? | toto fabella | 1 | |
| Better sub than SVS PB2-ISD | Nathan Morrow | 4 | |
| Radio Interference with PSB Subsonic 5i subwoofer | Stuart Garrett | 1 | |
| Which connection? | Poo | 5 | |
| 1st time subwoofer buyer looking for help | Brandon Konran | 9 | |
| Subwoofer directly to TV? | Anonymous | 3 | |
| Y- Connector on Subwoofers???? Pleae help.............. | Scot B | 9 | |
| Hook up car amp to computer or TV | JZsnowboardalot | 1 | |
| Memphis LVS subs | mojo_160 | 3 | |
| Help With Dual 4ohm Voice Coil | KEGGER | 4 | |
| Wiring up subwoofer???????? | J. Vigne | 3 | |
| Car Audio Sub to Computer or Home Stereo | Licence2ill | 1 | |
| Subwoofer cable? | ABC | 3 | |
| Help in Setting Up / Calibrating my Inifinity Speakers | Stray | 2 | |
| Infinity Subwoofer | Eric Bundy | 6 | |
| Hmm any one know whats wrong? | My Rantz | 2 | |
| Ohm Problem | riffraff777 | 2 | |
| No Sound from Sub | J. Vigne | 11 | |
| Dual tens in a box for home theatre | Nathan Morrow | 2 | |
| Subwoofer Thumping | KEGGER | 8 | |
| MTX Subs in Home Stereo Cabinets | Nathan Morrow | 3 | |
| My DIY home sub. | Nathan Morrow | 3 | |
| Can anyone tell me? | Gary Moore | 1 | |
| Crossover build | Nathan Morrow | 2 | |
| Single Sub output/dual input | Nathan Morrow | 2 | |
