PSB Image Speakers - Warm or Bright Sounding?
speakerchallenged
Would the PSB Image speakers be considered warm or bright?
I have always considered them to be on the bright side. They have aluminum tweeters and seem to accentuate the high notes.
Wouldn't that sound characteristic be considered bright?
From reading previous posts it seems others consider them on the warm side.
Username: Jamesp
Mansfield , TX USA
Post Number: 52
The image series sound warm to me as do the other canadian made speakers.
Username: Danman
Post Number: 98
Whoa! I used to own the PSB 6T and it is not like all Canadian speakers. I now own AXIOM and they are much more detailed in the mid range and highs than PSB. Also the the PSB's can be a little boomey at volume but are an excellent speaker.
Username: Look4sun
Post Number: 17
How if PSB Image 6T compare to Paradigm Monitor 9 ? Both of them are Canadian speakers and price in same range.
I already auditioned the Monitor 9 and they sound good and detailed. But I still no chance to compare the Image 6T.
Anybody have opinion on these speakers ? Which one is the better ?? Thanks all....
Username: Danman
Post Number: 100
Which one is better depends on you. Many people on these forums forget that important rule. One speaker may be good to you but not to another. Go out and try them.
