Wiring my subs
Username: Almost2asian
i had 2 10" 4-ohm subs, hooked up to a 760 watt 4 ohm amp. i bought 2 kenwood 700 watt subs, already in a box today, and it turns out they're 8 ohm subs. how should i wire this to achieve maximum power? also, how do i stop the rattling inside my car? i dont think its the doors or anything really needed to be dampened, i think its more of pieces in my car... interior lights, rear view mirror, etc..
Username: Jlprix91
Muskegon, Mi Usa
Post Number: 7
what model kenwood are they?
cmitchell
i need to know what type of wiring i need to hook up my 2 12" aw1206t audiobahn woofers and how much they will cost?
Username: Rickypearson
Post Number: 61
You could stop the ratteling by useing something called DYNO-MAT its a foam like material you place on the roof and doors of your car and it completly stops all the little annoying rattel sound. The only down side is that you looking to pay about 50$ or more a Square foot! so take a look at the stuff try it out and let me know how it works
Username: Bigmike22
Wyoming, Mi Us
my stuffs the best 3 15" alpines and a 1500 watt amp any one wanna battle
i just bought 2 audiobahn 12"immortals they are triple voice coils at 2ohm and i have a power acoustic lt1920-2 hyper bass series @2ohm stable,and i haven't been able to figure out the wiring for the sub to keep it at 2 ohms.so if you could please help out i would appreciate it.
thanks virgil
how do i wire 2 12" kicker comp vr subs to get the best sound with a rockford 1200watt 2 channel amp
uncircumsized
how do you circumsize your weiner on your own
