RECEIVER OR SEPERATE COMPONENTS?
ROGER
I CAN SPEND ABOUT $1500 TO $2000
SHOULD I GET A RECEIVER OR A PRE AMP AND AMP-
OR A GOOD RECIEVER AND ADD AMPS LATER?
ROGER
I SHOULD OF ADDED THAT FOR NOW I ONLY HAVE TO
MAIN SPEAKERS SNELL XA60S-I PLAN ON ADDING SPEAKERS LATER
benhogg@bigpond.net.au
hey there roger,
i would reccommend getting a pre amp/power amp as even the best reciever has to make comprimises to fit everything in the same box.
A good Pre amp/ power amp combination is The NAD C162 preamp which sells for around $500-$600 and the NAD C272 power amp which sells for around $700
both these products come highly recommended
or you can go for something similar from other brands such as denon or marantz
All the best
Ben
What if we bumped the amount up a little to say the $4000 range? I am looking at the Z9 and the 59TXi, but would be happy to get advice on separates that would be great for 80% HT usage. (59AVi DVD already)
Username: Edison
Post Number: 269
Snells are good speakers deserving good electronics - I would get used at www.audiogon.com to get more quality.
Something like this would be good.
http://cgi.audiogon.com/cgi-bin/cl.pl?ampstran&1079323432&class&3&4&
Username: Snakeyes
Post Number: 11
Get the outlaw audio pre/pro combo $1598 from outlawaudio.com i have been wanting to get them for some time now but i have to build my new room first. a friend of mine got them for christmas and they are great.
Username: Nathan
Post Number: 9
Dertman,
If you said total amount around $4000 range, then I would reccomment you go with NAD T163 and NAD T973. I just picked them up with Center speaker "Monitor Audio Silver" for $525 and some good cables around $300. Total up around $3925.00 for all.
NAD T163
NAD T973
Center speaker (Monitor Audio Silver)
4 Audioquest Diamondback 0.5M (Two cables in the box)
The NAD T163 and NAD T973 are 7.1, so would need 7 cables go from Pre-amp NAD T163 to Power-amp NAD T973
Hope this will help!!!
