Pre amp to use for Audiosource Amp Two
Username: Iammike
So i've been doing a lot of searchign the last few days for the pieces i want to put together for my home stereo system i've been wanting to build. I want to put something relatively moderate price while still being good sound.
the amp i want to buy is the Audiosource Amp Two.. I've seen some very favorable reviews for this amp.
My big question though is what pre-amp should i buy for my system that would compliment this Amp? Anyone have this amp now? what pre-amp do you use. Anything kinda around the same value range as the Amp Two? Just looking for any recomendations.
My first idea was to buy the Audiosource Pre-one preamp to compliment it.. since it has a good amount of inputs and made by the same company as the amp i want. Though i saw some mixed consumer comments on it. So i figured i'd as here and see if i can get some feedback.
Username: Edison
Post Number: 286
http://cgi.audiogon.com/cgi-bin/cl.pl?preatran&1079498355&class&3&4&
This one will be pretty good - better than the Audiosource one.
