New member Username: MikemoonPost Number: 1 Registered: 01-2004 | Looking for help... I just moved into a home that has 5 sets of built-in speakers in various rooms(don't know brand). I also have Bose 201 front and Infinity center speaker. I haven't set up my rear speakers yet. My Onkyo TX SV515 ProII doesn't seem to be able to power all of these. I do have an additional receiver if necessary. Any suggestions on the proper configuration? Thanks, Moon. |
New member Username: EdisonPost Number: 274 Registered: 12-2003 | You can connect the 2 receivers - take "tape out" of one receiver to "tape in" of theother. This way, you can hook up more speakers. You can use the method to hook up more receivers of amps if you want. |
New member Username: EdisonPost Number: 277 Registered: 12-2003 | You might want to get axiom m3ti speaker for the front, and use the Bose for the back. They will sound better. http://www.vertigoonline.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AMB S667 |
