New member Username: HtspkPost Number: 2 Registered: 01-2004 | where can I buy these speakers online in US.?I did a google search and found that most of the dealers were from uk.thanks. |
New member Username: BilldashillPost Number: 30 Registered: 12-2003 | None that I know of are authorized. Do you have a Tweeter's or Sound Advice store near you? I'm sure they are authorized dealers. |
Anonymous | check www.monitoraudiousa.com |
New member Username: Larry_dPost Number: 10 Registered: 12-2003 | I ordered my silver series from aboutgizmos.com. They seemed to have the cheapest on-line prices of the other companies I checked and I got them in three weeks(they're in NJ and I'm in SC). No dings or anything. I love 'em. The company is very friendly. You should give them a shot. I hope that helps. |
KidA Unregistered guest | SoundCity also has a lot of Monitor Audio stuff. |
New member Username: GmanPost Number: 116 Registered: 12-2003 | Write to Ginger at info@audiovideo4u.com. I bought Monitor Audio Gold Reference speakers from them last year. You can tell her that Greg in SC (the guy that bought 2 pr of MA GR 10's, GR center channel, and subwoofer from her last year)recommended her. Who knows--that might get you a better price. Good Luck |
