My remote control does not control the 752 very often. I have to get right up close and press a button 3 or 4 times. I have a remote control extender I sometimes use (Powermid) but it still won't control the receiver. Has anyone else had problems with the remote control on this receiver? What kind of equipment or extender products do I use to plug into the IR input on the back of it? Any advice would be helpful! I love the sound of my NAD, but being unable to control the volume consistently is giving my system an extremely low WAF, which makes my life miserable. Thanks!
Brockish
I would try replacing the batteries first and foremost. Could be lack of battery power. Try that!
Good advice, but tried it. It's both the NAD remote and the Harmony SST I got. Neither will control the NAD very well, but control all other components just fine. What about different remote extender products? How can I plug into the IR Input on the back of the NAD?
