Silver Member Username: Ez2ctvPost Number: 111 Registered: Dec-07 | Seems NFusion has working bin 1.49 that is getting a lot of N3 channels (PPV still down). Still not stand alone but IKS. |
Gold Member Username: PlymouthCanada Post Number: 5326 Registered: Jan-08 | Thanks Tony |
Gold Member Username: Saqeeb9000Post Number: 4157 Registered: Oct-07 | see told ya nfusion is best rec, and tony is the man thanks tony. |
Gold Member Username: Saqeeb9000Post Number: 4158 Registered: Oct-07 | c& p from nfusionforum. Originally Posted by terbwoolf View Post OK, I've tested this new bin (081106_nova_v149_0_t1.bin, downloaded from the files section of this site) using Wireshark packet sniffer and here are the results: Summary - I have monitored the detail Internet traffic (all IP traffic, which is the only traffic that can make it off of a properly configured home network and transport itself over the Internet) of the bin file, during both boot and normal operations and compared it with the boot and operations trace of a working 1.48.2 bin file. All IP boot and operational functions (packets) appear to be the same in both flow and structure, and both bin communicate with the same server IP address (119.42.149.27) This would tend to convince me that there is no "man in the middle"( or some such variation of this kind of attack/monitoring) monitoring going on. TRANSLATION - for those not so technically inclined, it looks like a valid bin file with no compromise or strange monitoring going on ... "test" at your own discretion. Caveats - I have so far only tested this with B3V (91) and will soon point to and scan 119, and 110, but I expect to find the same results but will not know for sure until I actually do the testing. This is in no way an implied guarantee that I am making ... if you are still concerned, or do not trust me then you should do your own testing. You should at a minimum have a look at your router logs, if your router has that capability, to determine if the IP address listed above is the one you are communicating with ... if it is not, then I have no real suggestion except to make sure you are running the bin file fro this site. If I see something different when I scan in and test any other bird (I will only be doing 91, 110, and 119) I will post an update. My current test on B3V has been running for approximately 20-30 minutes so far. I will continue to monitor probably for several hours just to be sure, again, anything strange that pops up I will update to this thread. Thanks. download yours at file has been tested by moderators at nfusionforum (2nd home site for nfusion box)...so nothing to worry about |
Gold Member Username: Saqeeb9000Post Number: 4159 Registered: Oct-07 | should get all of these channels for now 050 DVEpg 052 CBCDv 053 CTVDv 054 DvCTV 055 GLBDv 056 DVGlb 057 CTYDv 058 DvCTY 059 E!DV 060 DvE! 061 MCTV 062 CTV-w 063 CBC-W 065 Vision 066 BARDv 067 VICdv 068 GLSDv 069 GLCDv 070 CTMDv 072 OTTDv 074 PBSDv 075 DvPBS 076 CTV-c 077 CTV-e 078 GLB-w 080 WEA* 081 MET* 082 TREDv 083 HGTDv 084 HSTDv 085 TTeDv 086 TTwDv 087 TTfDv 088 COMDv 089 DVCOM 090 SPCDv 091 TRPDv 092 WeDVI 101 TVA-R 102 TQSRL 103 TVARL 104 TQSSa 105 TVASa 106 TQSSh 107 TVASh 108 SRCSh 109 TQS-Q 112 SRC-M 114 TQS-M 115 TVA-M 116 TVARN 118 SRC-W 120 SRC-V 121 TVA-O 124 RIS 125 MET-I 126 RDI 127 LCN 129 CAN-D 130 METEO 131 CAN-Z 132 SERIE 133 CAN-H 134 CAN-E 135 CAN-V 137 TFO 138 TELEQ 139 TOONF 140 VRAK 141 MSQPL 142 MUSMX 143 ARTV 145 TV5 152 CAN-S 154 IDMTV 159 VU-F 184 ALRT 187 ADR 198 XPRS2 202 ASN 203 CBC-H 204 GLB-H 205 CTV-M 206 CBC-M 210 CBC-T 211 GLB-T 212 CTV-T 213 SUNTV 214 CITYT 215 OMNI1 216 OMNI2 217 CHEX 218 E!ONT 219 A-BAR 220 A-LON 221 MCTV 225 CTV-W 226 CBC-W 227 GLB-W 228 CITY-W 229 ONHD 230 XPRS 232 XPRS* 235 CTV-R 236 GLB-S 237 CTV-L 238 CBC-L 239 CTV-E 240 GLB-E 241 CITYE 243 CTV-C 244 GLB-C 245 CBC-C 246 CITYC 250 CTV-V 251 CBC-V 252 GLB-V 253 CITYV 255 E!BC 256 A-VIC 258 CBCDC 259 CFJC 261 VISION 263 SWAP 264 SWAP* 265 TVO 266 SCN 267 ACCES 268 KNOW 269 APTN 270 APTNn 275 ITV 282 CBS-E 284 PBS-E 289 CBS-W 291 PBS-W 294 PEACH 295 WGN 296 WSBK 297 CW11 298 KTLA 308 MC1 309 MC2 310 MC3 311 EA1 312 EA2 323 MOVE 330 IFC 331 MVOLA 332 SCRM 333 DRVin 334 ACTN 335 DIVA 336 DOCU 399 EVNTS 400 TSN 401 TSN2 405 SNETO 406 SNETE 407 SNETP 408 SNETW 409 ESPNNc 410 SCORE 411 OLN 412 FOXSP 415 RAPTR 416 GOLF 417 SPEED 421 WFN 422 LEAFS 424 NHLVu 448 NFL-N 500 CNN 501 CTVNN 502 CBCNW 503 CP24 504 BNN 505 WEA 506 WEA-I 507 FOX-NC 508 HNN 509 CNBC 510 BBCWN 512 CPAC 515 TECH 521 TLC 522 HIST 523 CVIL 524 GEO 527 TRAVEL 528 COURT 529 BOOK 549 PHDIS 551 YTV-E 552 YTV-W 553 TREE 554 TOONE 555 TOONW 556 FMLY 557 FAN-W 562 BABYe 563 BABYf 564 BABYs 569 BFVSC 570 MUCH 571 MMM 576 BET 581 MTV 600 HGTV 601 SLICE 603 FOOD 604 HLTH 605 FTV 606 ONE 607 FINEL 608 COSMO 609 OUTTV 615 A&E 616 SHO-E 617 SHO-W 618 TROP 619 TROP-W 620 BRAVO 621 STAR 622 BIO 625 CMDY 626 CMDYW 627 SPACE 628 SPIKE 629 MENTV 630 MTIME 635 BBC-C 636 DEJA 637 TVLND 639 GAME 651 CTS 652 MIRCL 745 SEXTV 746 BLUVU 748 VUBUY 749 VENUS 760 VNS10 783 VNUS* 950 VOAR 951 OZ-FM 952 CBC1H 953 CJAD 954 Q107 955 EDGE 956 CBC1T 957 CBC2T 958 680AM 959 FAN 960 CJRT 961 POWER 962 WRN 963 96FM 965 NPR 966 NPR* 967 VPRNT 968 105FM 969 CBC1V 970 CBC2V 971 RFI 972 WAHSA 973 CKAC 974 CJPX 975 CC-M 976 PC-M 977 PC-V 980 RIGA 981 DESJA 982 METRO 986 HERZ 990 AM640 991 1200 992 960AM 993 CHED 999 DRM |
Silver Member Username: Mohamad_obamaTerhan, Iran Iran Post Number: 158 Registered: Oct-08 | Info on installing the new bin. C/P by the Crow For you D.N users ignore this , it is only for B.V and when the B.V users load this yes do a U27 Flash then load the new file and then do 3 Factory Defaults and reboot your whole system including the N-Fusion from back. Then rescan your antennas and assign your proper ports and Proxy/Emulator OFF and set to DHCP, never reload boot 1.30 because Matchstick said months ago this could cause issues with the box. I had mentioned this about a week ago the info. I received from Matchstick/CaptainJ77 that after the success that was had with the file that was written for N.F.L.S.T in regards to the N3 encryption, they would use this knowledge to create a file or program to counter N3 for B.V in 7months or less and for D.N in about 1yr. So here is to Matchstick and all the coders involved, and I will wait for mine when D.N goes N3 encryption. Good luck for all you B.V users , and remember to load carefully and unzip or extract the file before trying to install it. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3704 Registered: Oct-06 | I have been talking to a real computer expert And I mean real expert He told me that IKS is relatively safe to use specially to US residents So if yo can get all of these channels on BEV Then IKS is the new future for PTA I myself may consider IKS if I can get NFL ticket along with Movie Central |
Gold Member Username: Mc_sunnyPost Number: 1340 Registered: Feb-06 | Yup it an't really danger to use lol they are running like a sub |
Gold Member Username: Saqeeb9000Post Number: 4161 Registered: Oct-07 | its really good to hear from knowledgeable person like king and mc suny about nfusion and how safe it is,,, king i always recommend nfusion because of iks and iks is way for future, IKS is the new future for PTA , those companies who will stay behind will be out of business soon |
Platinum Member Username: NydasPost Number: 12882 Registered: Jun-06 | Sada: Keep up the info on Nfusion, IKS and Nagra3 |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3705 Registered: Oct-06 | Sada There is always a chance to get cought Just like the people load copy righted music But I just can't possibly see going after all IKS users Providers have to come up with some sort of ECM to shut IKS down I'm interested to see how long IKS stays on What channels yo get and what channels yor missing? etc. |
Silver Member Username: HshakarchiPost Number: 265 Registered: May-06 | With Nag3 soon taking over, Questions: - How does IKS work. - why is it not affected by Nag3 - Is it worth buying NFusion now. - Or should we wait for a fix. |
Bronze Member Username: TooterPost Number: 20 Registered: Oct-08 | C/P of a C/P 10-09-2008 ------------------------------ C/P from JM Nfusion did not hack Nagra 3 After having to read all these Bullchit announcements around the net, I thought I would put together a brief layout of what the Nfusion has done and why it is NOT a hack. First let me start off by explaining a couple of things. Your TV signal is Encrypted before it leaves the uplink center from your TV provider. The signal is gathered by your satellite dish and the beam is focused to the LNB . The signal travels down the coax cable to your receiver where the Smart Card and Conditional Access Module (CAM) process or decrypt the signal and you get video and audio on your TV. The security of the system is in the CAS. A providers CAS compromises of a Conditional Access Module (CAM) and a card. Some CAS only has Smart Card elements and other only CAM but it is assumed that the CAS has both elements in respect to the discussion of abstract security. Fta receivers and BIN files A Fta Receiver does what is called emulation. Emulation is in the BIN files you load to your receivers and basically means the software loaded into the Fta Receiver can now process or do the functionality of CAMs and smart cards in a providers receiver. This is sometimes called "stand alone". Fta Receiver and card sharing: A person with the subscribed card runs a Card Server on their reconfigured open receiver and listens for client communication on a given port (Here is the only risk with IKS but it is a huge one because it must get your REAL information. I.E serial # and IP). Entitlement Management Messages (EMMs) and Entitlement Control Messages (ECMs) are sent by the clients to the server which in turn decrypts and returns the control words used to scramble the content. The server carries out a unilateral authentication of the clients using the legitimate card and continues to exchange ECMs and EMMs allowing clients to access encoded DVB programs without subscriptions. The Card Server gives each client a thread and this is the only limiting factor of the network. The Server can only support as many clients as the card allows. The risk or flaws of IKS/cardsharing. The flaw with card sharing Nag3 (or ANY of the newer forms of encryption) is the card has knowledge of behavioral contracts and once violated it would deny services to the accessing box. In other words, the provider has a way to see how the card is behaving and send alerts when it see something that isn't right. So it limits the number of people who can be connected to the card server at one time. This probably explains why Nfusion only opened the server up for the HD units. So there was NO hack of Nagra 3 by the Nfusion. What there was, is a PUBLIC test of the limitations of a card share sever. Nothing more then a sales tactic. DO NOT be fooled into thinking Nagra 3 is hacked wide open or even close at this point. Nagra3 is hacked in Europe but ONLY small servers doing card share and no emulation bins are running at this time. __________________ Currently Testing: My neighbors wife... Some new Chronic... |
Bronze Member Username: El_keyPost Number: 87 Registered: Nov-08 | amen, people were almost starting to believe sadas broken version |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3706 Registered: Oct-06 | Sada Are yo getting these channels or not? If yo are, how long do they stay on? I read the C/P and it does make a lot of sense In that case IKS is a piece-a-crap But I just don't see how sada would post false info? Sada can yo please reply? |
Bronze Member Username: Perycles2005Post Number: 68 Registered: Mar-05 | All I have to say is some years ago there was the same thinking when Nagra 2 and everybody was saying it was the end of FTA...soon they were proved wrong...when the new Nagra 2 was Hacked...so time will tell...I am sure there is money involved and we will have our receivers working again... |
Bronze Member Username: Perycles2005Post Number: 69 Registered: Mar-05 | All I have to say is years ago it happens the same when Nagra 2 came Up and soon everybody was saying it was the end of FTA and they were proved wrong...FTA will survive and the Coders and the people involved will bring it back on time... |
New member Username: DexnperryPost Number: 1 Registered: Nov-08 | I fail to see the point in spreading rumors and lies about CS. Anyone who gets off their lazy behinds can see for themselves that CS through IKS has been the standard in Europe for more then a year. It's been used for DTV in North America and it works perfectly. It was used for Charlie/Bev during the Nag1 to Nag2 transition before a working cardless came out and it also worked just fine. Of course, none of the salesmen will tell you that. CS has also been the standard for thousands of Dreambox users FOR YEARS because many of them have never wanted to waste their time with latest and greatest cardless bins. The reality of it is, the ONLY people who don't want NA going to CS are the salesmen who front boxes like Viewsat, Pansat etc. They aren't prepared to go to CS, they haven't setup the systems and they know dam well the only thing they can do while waiting for a cardless fix is run a load of crap about electron microscopes being used to read the chips on the cards. The problem for them is that this time, there really may be no cardless fix. As a result, they want to sell as many of their boxes as possible before they pack up and get out. Fear not, they'll crop up again somewhere selling IKS boxes if that is indeed how this whole thing turns out. FACTS: Nfusion has a working IKS system. Nfusion is currently decrypting Nagra 3 channels for it's users. NO ONE ELSE HAS ANY WORKING N3 CHANNELS EXCEPT NFUSION. Nfusion is not F2ATV and never was, f2atv was a forum through which MANY boxes released fixes including nfusion. NO ONE has yet proven that what nfusion uses is in fact card sharing. Matchstick insists that IKS IS NOT card sharing and neither he nor anyone else with nfusion will say exactly how IKS works. Why would they and why should they? Neosat has thier own system and the nfusion people have always said that Neosats system will fail when put to the test under Nagra 3. Time will tell but one thing is for sure, today ONLY NFUSION boxes have Nargra 3 channels up and running, period. So while you nfusion bashers continue to sling the mud the rest of will get on with the hobby. In the end, you'll wake up and realize that you've been nothing but pawns of the salesmen. I said it at CC and I've said it everywhere else. All the information is out there for anyone to find if you look for it. |
Silver Member Username: JuanchoCANADA Xx Post Number: 184 Registered: Jun-08 | I have a xtreme and I dont't have problems with many regular ch,(bev) Tell me about ppv and porky's and that will mean somethings else to me (n3 ) |
Silver Member Username: Mohamad_obamaTerhan, Iran Iran Post Number: 161 Registered: Oct-08 | Until they get ppv's po rn and vod working, I don't think IKS or SUNS or what ever else you want to call it, has broken nag 3. If they had it broken all would be coming through, not just what you can get on a card share. Sada, I am curious, I know you have a nova and k-box. Are you getting all the channels you have listed? |
Silver Member Username: JuanchoCANADA Xx Post Number: 185 Registered: Jun-08 | today 500 cnn and others ch, are gone, bev is goings fast. I believe that the black out end this weekend , almost just french ch are left. |
Gold Member Username: Saqeeb9000Post Number: 4165 Registered: Oct-07 | first of all nalin and all u guys will be informed of what's happpening with nfusion and nagra 3 KING , Obama i loaded the bin yesterday, i am getting venus channels but no ppv's yet, i will do more testing on weekend if by chance can any one tell me few channels so i can check if they are working later on weekend, they didn't crack 100% N3 channels but some channels... |
Gold Member Username: Saqeeb9000Post Number: 4166 Registered: Oct-07 | with kbox i am not getting nagra 3 channels, with nfusion i am getting some nagra 3 channels , po*rn (venus) only no ppv so far, but those channels i am getting or definately nagra 3 channels, wierd no comments from just for hahha |
Gold Member Username: Saqeeb9000Post Number: 4167 Registered: Oct-07 | and one more thing i double checked and all the channels i reported above are working fine,, https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1642722#POST1642722 if some one can tell me any specific channel just post it here and i will check on the weekend |
Gold Member Username: Cartier1Post Number: 2152 Registered: Feb-07 | the question that made me confused is : if nagra 3 is cracked by nfusion what we can watch somechannel and not see others.???/ |
Gold Member Username: JustforhahasPost Number: 1058 Registered: Jul-08 | Nfusion and IKS is just old fashioned card sharing like tooter posted above.. N3 is NOT cracked by anybody now!,,and I don't care what matchstick (sales for Nfusion) or anybody else says!... |
Gold Member Username: PlymouthCanada Post Number: 5349 Registered: Jan-08 | Thanks Sada for the reply haha N3 is cracked in Europe, but you need to pay for it. Do a search on Web |
Gold Member Username: JustforhahasPost Number: 1059 Registered: Jul-08 | No its card sharing in Europe... |
Gold Member Username: PlymouthCanada Post Number: 5351 Registered: Jan-08 | Haha I have a couple of sites with good info but as usuel, if i give those sites, you go take it and post on your own site. Do your search and stop your false info. Sada say than N3 is broke and he is able to see it, you agre than those channels are on N3, now explaine us why he can get it. |
Platinum Member Username: NydasPost Number: 12890 Registered: Jun-06 | Sada: Please, Please keep up your good work and keep on posting the facts. I had all these hecklers to deal with, many a time, and you simple ignore them and continue. Most of the so called nerds whose C/P you are confronted with, have not worked with real low level and CPU level software that hackers use to understand the minds of encrypters. They are not bothered by 'Conditional Access Module (CAM)' and 'CAS' - they are more in tune with the numbers coming down and mathematical methods of encryptioo/decryption. |
Gold Member Username: Cartier1Post Number: 2160 Registered: Feb-07 | NOVA THE ONE I HAD . IM JUST WAITING FOR THE N3 TO CRACK I WANNA GO FOR HD. I JUST BOUGTH NICE LCD 52' 1080P 120HZ 4MS 50.000 RATIO |
New member Username: TerebichanPost Number: 2 Registered: Nov-08 | Nfusion cannot get any N3 channels at this time. Version 1.49 look like a placebo version and nobody knows who is the author. Nobody have news from Matchstick since F2A is down. At this time Nfusion look more like a no support than the leader of N3 cracked box. |
Silver Member Username: Tigger_woodsWONT BE GOLFING, UNTIL BUICK OPEN Post Number: 755 Registered: Jun-07 | Today, 07:44 PM ledyjr Visiting Mod/Admin Join Date: Jan 2008 Posts: 176 First Release On N3... WORKING!!! -------------------------------------------------------------------------------- First Release On N3... WORKING!!! ***********C&P*********** Well Guys: Nfusion does it again they prove to the world that they are here to stay and NOT EVEN N3 is going to stop THEM. There latest Release T1 is the first N3 File... To fix the issue with B3V... There will be more to come from the Nfusion Team... We can count on that... Way to go Nfusion #1 --------------------- Channels for now are back up with this first release: 050 DVEpg 052 CBCDv 053 CTVDv 054 DvCTV 055 GLBDv 056 DVGlb 057 CTYDv 058 DvCTY 059 E!DV 060 DvE! 061 MCTV 062 CTV-w 063 CBC-W 065 Vision 066 BARDv 067 VICdv 068 GLSDv 069 GLCDv 070 CTMDv 072 OTTDv 074 PBSDv 075 DvPBS 076 CTV-c 077 CTV-e 078 GLB-w 080 WEA* 081 MET* 082 TREDv 083 HGTDv 084 HSTDv 085 TTeDv 086 TTwDv 087 TTfDv 088 COMDv 089 DVCOM 090 SPCDv 091 TRPDv 092 WeDVI 101 TVA-R 102 TQSRL 103 TVARL 104 TQSSa 105 TVASa 106 TQSSh 107 TVASh 108 SRCSh 109 TQS-Q 112 SRC-M 114 TQS-M 115 TVA-M 116 TVARN 118 SRC-W 120 SRC-V 121 TVA-O 124 RIS 125 MET-I 126 RDI 127 LCN 129 CAN-D 130 METEO 131 CAN-Z 132 SERIE 133 CAN-H 134 CAN-E 135 CAN-V 137 TFO 138 TELEQ 139 TOONF 140 VRAK 141 MSQPL 142 MUSMX 143 ARTV 145 TV5 152 CAN-S 154 IDMTV 159 VU-F 184 ALRT 187 ADR 198 XPRS2 202 ASN 203 CBC-H 204 GLB-H 205 CTV-M 206 CBC-M 210 CBC-T 211 GLB-T 212 CTV-T 213 SUNTV 214 CITYT 215 OMNI1 216 OMNI2 217 CHEX 218 E!ONT 219 A-BAR 220 A-LON 221 MCTV 225 CTV-W 226 CBC-W 227 GLB-W 228 CITY-W 229 ONHD 230 XPRS 232 XPRS* 235 CTV-R 236 GLB-S 237 CTV-L 238 CBC-L 239 CTV-E 240 GLB-E 241 CITYE 243 CTV-C 244 GLB-C 245 CBC-C 246 CITYC 250 CTV-V 251 CBC-V 252 GLB-V 253 CITYV 255 E!BC 256 A-VIC 258 CBCDC 259 CFJC 261 VISION 263 SWAP 264 SWAP* 265 TVO 266 SCN 267 ACCES 268 KNOW 269 APTN 270 APTNn 275 ITV 282 CBS-E 284 PBS-E 289 CBS-W 291 PBS-W 294 PEACH 295 WGN 296 WSBK 297 CW11 298 KTLA 308 MC1 309 MC2 310 MC3 311 EA1 312 EA2 323 MOVE 330 IFC 331 MVOLA 332 SCRM 333 DRVin 334 ACTN 335 DIVA 336 DOCU 399 EVNTS 400 TSN 401 TSN2 405 SNETO 406 SNETE 407 SNETP 408 SNETW 409 ESPNNc 410 SCORE 411 OLN 412 FOXSP 415 RAPTR 416 GOLF 417 SPEED 421 WFN 422 LEAFS 424 NHLVu 448 NFL-N 500 CNN 501 CTVNN 502 CBCNW 503 CP24 504 BNN 505 WEA 506 WEA-I 507 FOX-NC 508 HNN 509 510 BBCWN 512 CPAC 515 TECH 521 TLC 522 HIST 523 CVIL 524 GEO 527 528 COURT 529 BOOK 549 PHDIS 551 YTV-E 552 YTV-W 553 TREE 554 TOONE 555 TOONW 556 FMLY 557 FAN-W 562 BABYe 563 BABYf 564 BABYs 569 BFVSC 570 MUCH 571 MMM 576 BET 581 MTV 600 HGTV 601 SLICE 603 FOOD 604 HLTH 605 FTV 606 ONE 607 FINEL 608 COSMO 609 OUTTV 615 616 SHO-E 617 SHO-W 618 TROP 619 TROP-W 620 BRAVO 621 STAR 622 BIO 625 CMDY 626 CMDYW 627 SPACE 628 SPIKE 629 MENTV 630 MTIME 635 BBC-C 636 DEJA 637 TVLND 639 GAME 651 CTS 652 MIRCL 745 SEXTV 746 BLUVU 748 VUBUY 749 VENUS 760 VNS10 783 VNUS* 950 VOAR 951 OZ-FM 952 CBC1H 953 CJAD 954 Q107 955 EDGE 956 CBC1T 957 CBC2T 958 680AM 959 FAN 960 CJRT 961 POWER 962 WRN 963 96FM 965 NPR 966 NPR* 967 VPRNT 968 105FM 969 CBC1V 970 CBC2V 971 RFI 972 WAHSA 973 CKAC 974 CJPX 975 CC-M 976 PC-M 977 PC-V 980 RIGA 981 DESJA 982 METRO 986 990 AM640 991 1200 992 960AM 993 CHED 999 DRM One adult channel and some PPV channels are also working with this release. Stay tuned for updates... Enjoy It... Good Luck... From Caribbean!!! ledyjr View Public Profile Send a private message to ledyjr Find all posts by ledyjr Add ledyjr to Your Buddy List #2 Today, 09:20 PM NaughtyAngel Naughty Lil Thing! Join Date: Jun 2007 Posts: 2,729 Thanks ledyjr!!! If this is true then it looks very promising for others stb's as well!!! __________________ NaughtyAngel View Public Profile Send a private message to NaughtyAngel Visit NaughtyAngel's homepage! Find all posts by NaughtyAngel Add NaughtyAngel to Your Buddy List #3 Today, 09:45 PM nuttyproffesser VIP/Site Supporter Join Date: Oct 2007 Posts: 564 but this is a real Bin or the card share work around __________________ nuttyproffesser View Public Profile Send a private message to nuttyproffesser Find all posts by nuttyproffesser Add nuttyproffesser to Your Buddy List #4 Today, 09:56 PM jarhead Seasoned Vet. Join Date: Jan 2008 Location: Everywhere Posts: 245 Now Thats a good Question .IKS isn't working off bins .So i say pretty soon we will find out the real truth of Nfusion's act . __________________ The deadliest weapon in the world , is a Marine and his rifle . jarhead View Public Profile Send a private message to jarhead Find all posts by jarhead Add jarhead to Your Buddy List #5 Today, 10:44 PM gt5268 Registered Member Join Date: Feb 2008 Posts: 22 Can anyone confirm that the bin works on B*V ?? gt5268 View Public Profile Send a private message to gt5268 Find all posts by gt5268 Add gt5268 to Your Buddy List #6 Today, 10:52 PM plastikman Senior Member Join Date: Jan 2008 Posts: 77 all i can say is WOW.. awsome work guys.. NFUSION ROCKS plastikman View Public Profile Send a private message to plastikman Find all posts by plastikman Add plastikman to Your Buddy List |
