Username: Thetaffey Post Number: 42 Registered: Feb-08
Thursday, August 28, 2008 - 16:18 GMT How Long till Nagra 3 is fully implemented in the stream? Anyone know Is this encryption system crackable?
Username: Tapeman New York City in-HD,
NY
Post Number: 3308 Registered: Oct-06
Thursday, August 28, 2008 - 16:54 GMT Everything is crackable But to estimate exact time is totally unknown at this time I also think only B#V is swaping card D#N is taking an entirely differnt path I don't know if B#V completed all card swap Since I don't live in Canada To my best estimate I say end of September possibly October 2008 I don't know if all the sudden they decided to take same path as D#N and change entire hardware concept Everything is possible at this time But as a wild guess I say they'll take 2 different path One changing security card Other changing entire system concept If indeed this happens B#V will turn cold this Fall 2008 D#N will remain wide open until fall of 2009 I hope this helps to predict forcast a little
Username: Lomna Post Number: 313 Registered: Dec-07
Thursday, August 28, 2008 - 19:05 GMT K.T You are so smart ! how come ? I wanna be like you.
NY
Post Number: 3313 Registered: Oct-06
Thursday, August 28, 2008 - 19:18 GMT Nothing too smart It's common sense or educated guess Investgators have to follow trails and use educated guess Many times trails can turn cold I could be pissing in the wind if my strategy is wrong
Username: Obamabinbiden Piece,
Of
Shit
Post Number: 4 Registered: Aug-08
Thursday, August 28, 2008 - 19:44 GMT DN card swap is under way!
Username: Afg_paramin Post Number: 76 Registered: Dec-07
Thursday, August 28, 2008 - 22:39 GMT i heard it will come into effect when new channels launch usually in september
Username: Psychmonster Rhodium Member aint nuthin...
Post Number: 900 Registered: Jul-06
Friday, August 29, 2008 - 01:38 GMT nag 3 has been in portugal for 2 1/2 years and no hack yet...compare to d4 direct tv card
