Pansat 2700 Clone help av or anyone
Username: Fahadriz8
Post Number: 75
Hey guys simple question. whats the difference in the file name between a 2700 real file and a clone file. and is the 2700 clone file out? thnx
Username: Satgrl
Post Number: 701
it will say clone safe..that means its for clones
Username: Fahadriz8
Post Number: 76
can someone link me to a 2700 clone safe file?
Username: Nydas
Post Number: 5252
Genuine Pansat 2700 BINs are made by BL (BlackList), use a 27.02 loader, and appear first in the Pansat 2700 thread of
[link removed]
[link removed]
http://www.totalfta.com
Username: Fahadriz8
Post Number: 77
Nalin how come i cant download from dssrookie even when im signed in?
Username: Asharfi
Post Number: 1479
Vince Carter,
Go to www.dssworld.co.nr and download the clone safe file for Pansat 2700. Clone safe is a file that doesn't have the kill code in it. The real Pansat 2700 bins have kill code, which will destroy any unit other than Pansat 2700, so by removing the kill code, those bins can work on the clones of Pansat 2700.
Username: Nydas
Post Number: 5259
You will find downloads easier from AV's site and more help there.
[link removed]
Username: Rah
New York, NY USA
Post Number: 14
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1326590#POST1326590 need your help I have a prob with the Bl loader i need the RS 232 fm-fm cable and all I have is the Null cable for my new 2700a that I have working now I need to convert my 2500a to the 2700 and don't have a cable for it is there anyother way to load the bin's with the one I have?
Username: Nydas
Post Number: 5266
You can buy a straight RS232 cable from Radio Shack or similar place or you can buy a M/F null adaptor and use it in series with your your current null cable.
