One of these days King, one of ur predictions HAS to come true. If for no other reason, plain old dumb luck. Cant be wrong ALL the time. Good luck on the next one.
Well if yo only ask civilized questions I would be gladly answer it instead of attacking my integrity.
The simple straight forward answer concerning hardware: When they do an ECM they are simple microprocessor opcodes instructing the MP to perform instructions that causes firmware bios to keep rolling constantly like a virus. Not possible to target all receivers with one ECM.
They are so pissed off at View Tech and wanted to hit em where it hurts
The viewsat file release was delayed because this new Dishnet provider 0106 began with only 1 channel (ESPN)...and then SLOWLY it progressed into other channels...so Viewsat simply waited until 0106 had been applied to ALL the DN channels before they did a release...no sense releasing a new bin prematurely with bugs...and most current problems are because people are using CLONE receivers (but they don't know it), or not rechecking their antenna receiver settings, or did an improper upload of the files..
I do not think that the people at Viewtech or at totalfta site are stupid. If they released a BIN, it would be properly tested and unlikely to cause problems. Therefore, it is imperative that you check, 1. the fuse, if no power at all; 2. Did you upload the correct BIN? 3. Uploading procedure - was it done properly, and did you wait long enough. 4. Are sure you did not use a clone receiver? 5. Have you made changes to your Dish pointing or connections or disEqC settings?
In other words, try and find a fault with yourself before blaming the manufacturer.
Many times the antenna settings will change by themselves with a new bin upload...I think inexperience is a big factor in most problems being reported..
That WAS a civilized question. U ARE THE ONE ATTACKING UR OWN INTEGRITY WITH ALL THESE "THE SKY IS FALLING THREADS" AND NONE ARE COMMING TRUE. I cant see why u keep doing it?? Y do u keep insisting how great u are testing when u r CONSISTANTLY wrong? U talk about ur background, ur knowledge, ur testings, ur findings, the end of PTA, yet nothing... And obviously this isnt the only site u do it. U have to work for DN. Thats the only explaination y u would do this. I think u are an unskilled person who DN put here to spread panic to slow the purchase of FTA boxes, who has learned a great deal about FTA to do ur job better. If thats true, u have done ur part. Sooo, what ur next theory??
U do NOT have to be changing sats, for the antenna settings to change...just a simple bin upload can cause this change...this is electronics and software created and used to emulate a subbed eeprom...things happen...and its NOT only to Viewsats, its all receivers!
Use of FTA receivers is NOT technical at all...
aim the dish, run the cables and switch (if needed) config the antenna settings (so your receiver knows what U did) scan the channels/sats load up a new current file input latest keys via autoroll or manually watch TV..
What's up LK? Been gone for a while. Do you do all the above in that order? Can't you have the new bin installed before you do the configuring and scanning?
"U do NOT have to be changing sats, for the antenna settings to change...just a simple bin upload can cause this change...this is electronics and software"
Thank yo boss these noobes got no clue that it takes a microprocessor command to look at the antenna settings
