Monitor Audio Bronze
Username: Htspk
where can I buy these speakers online in US.?I did a google search and found that most of the dealers were from uk.thanks.
Username: Billdashill
Post Number: 30
None that I know of are authorized. Do you have a Tweeter's or Sound Advice store near you? I'm sure they are authorized dealers.
check www.monitoraudiousa.com
Username: Larry_d
Post Number: 10
I ordered my silver series from aboutgizmos.com. They seemed to have the cheapest on-line prices of the other companies I checked and I got them in three weeks(they're in NJ and I'm in SC). No dings or anything. I love 'em. The company is very friendly. You should give them a shot. I hope that helps.
KidA
SoundCity also has a lot of Monitor Audio stuff.
Username: Gman
Post Number: 116
Write to Ginger at info@audiovideo4u.com. I bought Monitor Audio Gold Reference speakers from them last year. You can tell her that Greg in SC (the guy that bought 2 pr of MA GR 10's, GR center channel, and subwoofer from her last year)recommended her. Who knows--that might get you a better price.
Good Luck
