Username: Bunkeredpb Post Number: 4 Registered: 01-2004
Thursday, January 08, 2004 - 20:03 GMT does jl audio subs come with a box.
Username: Ukw10 Post Number: 43 Registered: 12-2003
Thursday, January 08, 2004 - 23:49 GMT most of the time you have to buy subs and box seperatly. If you are buying jl audio subs, make sure to get good box that is made of MDF.
Username: Glasswolf Post Number: 573 Registered: 12-2003
Friday, January 09, 2004 - 02:05 GMT JL sells pre-fab boxes for their subs, but no the subs do not "come with" an enclosure normally. This allows you the freedom to build or buy a box to fit your needs.
