X-treme Pro Programer
I have an X-treme pro Programer. I downloaded extreme hu and ran it it says its detected on comm 1 and everything at the bottom of the screen but then when i got to clean card or anyting with the card it says please insert card and i do and it doesnt do anyting for a bid and then says timed out waiting for card. So i downloaded another program and it said something like invaild atml flash or no loader... Can someone help me i am not sure what to?? I dont know where to find flash either?? thanks Drew
timeout error fix for Drew
Drew, go to any web site that sells script, look for a program "VBRun60sp5" this should fix your timeout error, here is one of many web site: northdss. Hope this help, good luck.
I have a Apollo bootstrap. It is blue in color.
(when I program it with my hu card it only runs for 1/2 hr and then the picture freezes. It then asks for a valid card. I then take the apollo out an insert the hu card and everything works. What am I doing wrong? appreciate any help.
jhkfdghgghhjhashjhghjjfd
The extreme pro programmer is not for the hu card. http://www.Pro3m.tk
