Is 15V ok for my amp?
def man
I just hooked my new audiobahn amp up in the car and before even touching the settings I checked the voltage the amp was getting to make sure everything was hooked up right and my multimeter told me it was getting 15V, I later hooked some subs up and put some music on and it sounded fine but just to be sure is 15V healthy for my amp will it damage it?
Username: Glasswolf
Post Number: 541
15V is a charging voltage.
that's normal, and it's fine.
def man
thanks
