Advice needed from glasswolf
Username: Capulina6
hey glasswolf i was wondering if you were familiar with Concept amps, if you are would you be able to tell me why my CC-D1200A mono amp has two speaker outputs as if it were a 2/channel amp??? i am stuk on his and dont know how to wire my subs to it as i was expecting only one output
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1984
two sets of terminals for wiring two subs to the amp
it'd be a parallel set of terminals so using both will wire the subs in parallel for you
if you have two 4 ohm subs, wire one to each set of terminals.
simple as that.
the manual should have explained that.
