New member Username: CiscoPost Number: 1 Registered: 01-2004 | Im planning to purchase 2 12"-tdx dual 4ohm diamond woofers for my car? What type of diamond amp should I run these woofers? |
smart-as$ Unregistered guest | a good one |
New member Username: 01gsxrPost Number: 7 Registered: 01-2004 | get 2 D7 7402 each amp has 1600 wats rms at 4ohms. There verry nice amps witch will throw you back about 1000 a piece.There Thd is 0.02 nice!!!!! Your $hit will bang and look hot to. |
Anonymous | A friend of mine bought two TDX 12's and a U.S. Amps USA-2000 at audioperfect.com. They sound awesome! And they guaranteed service for the length of the factory warranty period. http://www.audioperfect.com/shop/catalog/product_info.php?cPath=3_25&products_id =104 |
