Wharfedale Vs JBL
Username: Flagerr
I Wonder which one better paired with my NAD T760, Wharfedale Diamond 8.3 floorstanding type or JBL in the same class (sorry I forgot the type). Anyone has better suggestion ?
thx a lot :-)
Username: Edison
Post Number: 211
Diamond is better.
These are as good if not better.
http://www.vertigoonline.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AMB S667
CBM-170 ascend acoustics:
http://www.ascendacoustics.com/Main/Intro/Firstpage.asp
They both sell direct, cutting out the middleman, to give more for the buck. They also got great reviews - you can read them on the sight.
You can try them out and return them if you are not satified. Home is the ideal place to try speakers - with your components, and in your room (acoustics), with your favorite music.
www.axiomaudio.com - for reviews. The other sight is cheaper though.
