help, currently this is my set up: deck,amp,woofer,4 speakers
the amp is powering the woofer, and the 4 speakers running off the deck. i've got a new 4 channel amp, which i want to run my 4 speakers off, but dont acutally know how.
my deck only has 1 pair of RCA holes..and that leads to the amp powering the sub.
what are my options here?
can i get power from the 1st amp...instead of going straight to battery again?
if the power line is of sufficient gauge, use a power distribution block at teh amps to split from say, one 4AWG to two 8AWG for teh amps, so yes you can.
for RCA you need an electronic crossover to handle that. the Coustic XM-3e would be a perfect solution.
