This is wassup. 2 12" Brahmas in a dual chambers box, each chamber will be about 2.0 to 2.3 Cu ft, not sure on how big yet.And it wil be ported to what ever Hz.
Hifonics 1500D mono amp
wire it to a 1 ohm load if bolth subs are dual 4 ohms.
What do you guys think.... please dont slam me, i dont have a assload of $$$ eather so dont tell me to get 2 13w7's and two 1000/1 jl amp's please
kick a$$ system although you might(might) be underpowering your subs a bit but, I doubt it, I would also recomend 1 15in brahama in a snail shell box on the same amp
Well, the only other thing I can think of your HO alternator, Especially running that amp @ 1ohm. Something to consider. Hate for you to get 2 Brahmas and go to turn it up a little and your charging system not be able to support it. Do you know how many amps your alt is....
Well i got a 01 grand cherokee and i think it is over 160. . . but i'v seen aftermarket ones that are 220 amp that i could get but they are pricey.
David- i think 750 watts for each sub should be plenty. . . according to Adires site and from what other people have told me, because it is quite the size box, the bigger you go, the less power your going to need. but i could be wrong.
One more question, is there any car audio stores in michigan that carry the 12" mark II brahma or whats the best mail order or online vendor i can go to???
Has a little more SPL due to surface area and a tad more excursion. IMO, the SQ of the Brahma and X.X.X. top the W7 though. Brahmas and X.X.X. tend to need less power and work better with less power.
Well i like it loud when i want it to be and sound good to. So i sure do want SQ/SPL so i would guess not a huge or small box??? but not sure on how big i want to make it yet.
