Anonymous | Here is what I think what will be my completed system (except for the speaker amp still deciding) Sub: RE 12" X.X.X Ported box tuned at 30hz Sub Amp: JBL BP1200.1 Speakers: Front- Infinity Kappa 6.1 components Rear- Infinity Kappa refernce 63.5i coaxils Speaker amp- Unsure, something about 450.4 <300$ HU: Pioneer DEH-9600MP Dynamat as needed Just wanted to see everyones thoughts on this set up for a 60/40 sq/spl user. Also guesses at what you think its total cost will be. Thanks guys! |
Silver Member Username: A3formePost Number: 130 Registered: Sep-04 | Sounds good really, just drop the rear speakers, you won't need them. It will mess with the sound stage. Then I would go with the Eclipse 33230 for the amp. It's $229 on www.Woofersetc.com. Or the JL 300/2. |
Bronze Member Username: Document_cNY Post Number: 21 Registered: Sep-04 | Im keeping the rears because of the amount of people I transport in my back seats so I want to give them a good audio experience as well. I will power them lower than the components though in order to maintain good sound stage. |
Bronze Member Username: Erik123456Arlington, Tx Post Number: 79 Registered: Aug-04 | why the pioneer hu? are you set on it? |
Bronze Member Username: Erik123456Arlington, Tx Post Number: 80 Registered: Aug-04 | im just testing to see if it takes the last name of my posts |
