75 watts RMS x 6 at 4 ohms 105 watts RMS x 6 at 2 ohms 210 watts RMS x 3 bridged output 3-, 4-, 5-, or 6-channel output Tri-Way capable MOSFET power supplies High-pass/low-pass crossovers, (50-500 Hz, 18 dB/octave) Selectable 18 dB bass boost at 50 Hz 3 sets of preamp inputs Cooling fan Cobalt blue illumination Digital voltmeter
i am trying to hook up 2 audiobahn subs but i have never hooked up subs to a 6 channel amp can some1 describe how i would be able to hook up the wiring and to which channels to hook up to because right now im getting a little bass out of the subs but also sound, i want to eliminate the sound from the subs and only have bass, thnx in advance
