Are there any simple cheap amps out there
My stereo just daunt put out enough power. Dose anyone make a 2 or 4 channel amp something with maybe a gain and blance control and that is it. i will use my stereo as a pre amp so an equalizer will be taken care of. I am looking for at least 20watts rms. per channel.
I looked at PA rack mount amps but that are like 600$.
Derek
Get a Pioneer receiver. 100 watts times 5 can be had for $150 on sale. Sherwood also makes receivers starting at $89.
Hope this helps.
Are you only looking for 20w or is that a typo? If that is all the power you are looking for and want high current power check out the parasound Zamp http://www.parasound.com/products/specialty/zamp.html
Parasound is a premier audio company making some of the best stuff on the market.
Wacey Hall
I am looking for a cheap 1000 watt or better amplifier. Preferable name brand. I keep burning out the ginaric brands.
Derek
Here's http://www.hometheaterhifi.com/volume_10_3/buttkicker-bka-1000-amplifier-9-2003.html 1100 watts for $500.
