Anonymous | I just obtained an Alpine MRP-M350 to power a 10" 225w @ 4ohm. Should I pick the KnuKonceptz 8ga or 4ga? The 4 seems a little excessive for this application... any thoughts? Alpine manual says 8ga or better for power wire. All this is being hooked to an Alpine CDA-9827. |
New member Username: Wicked_sinPost Number: 8 Registered: Aug-04 | try this site below, it will help you out. http://www.the12volt.com/info/recwirsz.asp |
Anonymous | Excellent site. Thanks! |
Bronze Member Username: A3formePost Number: 59 Registered: Sep-04 | 8 gauge is fine for 200W amp |
Gold Member Username: Jonathan_fGA USA Post Number: 1619 Registered: May-04 | 8 guage is plenty, but if you plan to upgrade or add another amp later, you'll be better off going ahead and getting 4 guage. |
