Anyone know where i can get the wire colours that come out of the 2001 bose stock amp? I'm installing my own and would rather use the stock wires than run new cables through the car.
well aftermarket amps require more power than stock amps so you will still need a instillation kit atleast for the power and ground wire. your only going to be able to use the turn on, line out, and speaker leads from the stock amp.
