Maybe the wrong place but....
Username: Cmangle
A question about Sony SoundForge...
I need to be able to adjust the EQ, WHILE the clip is playing.
Under "Process" the EQ listed stops the clip from playing.
Is there a real time way to adjust EQ?
Username: Sungamer
New York, NY USA
Not in Soundforge. Use a mixer (digital or otherwise)
Username: Cmangle
thanks Mei-Ying
you're in NY I'm just outside of AC
Username: Cmangle
sorry Mei-Ting
Username: Sungamer
New York, NY USA
Post Number: 9
Just had another thought on this - Depending on what you need to do, you might be able to use this.
Start the eq, then do a realtime preview. Then you can adjust the EQ and listen to the changes.
