munster Unregistered guest |
Posted on It is for 2 8 ohm subs and 1 12 ohm sub, it also needs to give the subs 500 w rms. the subs will be wired in parallel. |
Posted on That AMP, doesn't exist! |
Bronze Member Username: Fishy
Post Number: 18 Registered: Sep-04
Posted on JL 500/1 1/(1/8 + 1/8 + 1/12) = 3 ohms altho mixing impedances ain't a good idea if SQ is of any concern. -Fishy |
