Adding a higher fuse
Username: Thumprms
DaltonUSA
Post Number: 27
will replacing my old fuse with a higher fuse damage the amp?
for example: 30 replaced with 35
that guy with the face
yes
What if the amp is 400 watts at 2ohm with a 30amp fuse. Can i use 4 gauge wire?
Username: Jonathan_f
GA USA
Post Number: 1599
Yes, it could damage the amplifier. And anon, you can use 4 gauge, but as you probably know, it's overkill. It won't hurt anything. 8 guage would work for a 400W amp, but the good thing about 4 guage is it leaves you plenty of room to upgrade. You may have trouble fitting 4 guage in the terminal, though.
