Blackbird Receiver password
Username: Hungryforfood
favorites, channel up, volume down, info, green button, power, mute, epg
For start-up follow these instructions.
Hit Following Keys...
Menu
User Preference
Reinstall
Type Password
Should read all data erasing
- Question "Are you Sure?
- Hit ok
Will erase Old Software
Please Re-start the back of receiver for 10secs
Once Back On Hit Following Keys...
Menu
Vol + to TV Channel
Hit ok
Menu
Chan -- to delete
Vol + to all Channels
Hit ok
Will exit menu
Hit ok on any number and X will appear over numbers
Hit exit
Chan + to OK
Hit ok
Exit unit saves data.
For Channel Download follow these instructions once dish is in right position.
Menu
Installation
Transponder Setup
Hit ok
Vol + to correct dish
Choose sat scan
Hit ok to download channels
Wait until reads COMPLETE, not 100%
Hit ok
Exit until saves data and watch TV
Thanks to DSSMILLI.com
We are trying to start up our system, but we can't follow the steps, because the "user preference" step does not appear after menu. Can user preference be substituted for something else?
Have a Pansat 2500a Haveing problems: I move the dish 500 and signal metter does not do anything tried to hook up signail meter it does not get any power like the Pansat is turned off or something, put meter on the dish with RCA receiver and it gets power and shows signal Can not get into perntial controls unless i want to clear out flash and start with factory setings
Please e-mail me because this is driveing me nuts!!!!
I have had this putter for 2 weeks with no answers!!!
Username: Ckobmc
Post Number: 12
Are the Blackbird and or Silverbirds still working? A few of my friends went down. Is it worth buying a pansat or fortec for a little less?
lona
I just received my Black bird. I can't stop the on sceen menu from rolling to start my reinstall process. Also the remote control is different from the one in the manual
lona
Is the password "thread" for the blackbird?
skyhawk
Iona, the password i used was dsscanada.ca and it worked for me. make sure you have a null and modem cable and the pff4.01 fix.
J A
I was thinking about buying a blackbird but have heard that people are having trouble lately. I thought these boxes were not susposed to go down. Are they worth buying?
JA - I thought the same thing. I had my for only one day before some type of glitch happend. Now my seller is selling then much cheaper with free shipping. Make sure u do your homework before buying. All I got is a headace and loss of $$$$.
J A
Hey Hobo2,
My contact is offering the boxes at a lower price too. What a coincidence! So you are saying your box is not working at all now?
Can I ask you what kind of dish you had and did you install the system yourself? I have an old Direct TV dish but I'm told I need two dishes or a double dish to receive all the dishnet channels.
Does anyone know where I can find the fix for the blackbird receiver pizza 5.01? Who has information on the ST-1000 chip, if you have info should I return box to dealer for replacement chip.
Username: Denny
does anyone known if i can get the local channels under the 100's , i live in montreal and my sub is from atlanta, thanks
hobo2
JA- I have an old sony dish. U can try this website for a fix. It's dsschannel.com. User name : dsschannel Password ebay. Good luck! My friends is working I have not tried it yet.
cja
Will the pansat 2500a work in Queensland Australia and what chanels would it pick up
MY blackbird Reciver Jusat Reboot it self. it not given any channels,
any suggestions??
hi just got my blacbird it keeps rolling can't get to menu what am i doing wrong
Fever
Does anyone have a different BB password?
I just got my unit fixed and cannot get it to flash...
How do I configur my Blackbird receiver with my laptop using the null modem cable? What type of software do I need? Where can I get pff4.01 fix?
doc1ca
Yes it will work in Australia
