Wednesday, September 08, 2004 - 20:59 GMT i have a 1300watt ma audio amp mono channel could i do btter
Username: Stevencarr Arlington,
TX
United States
Post Number: 4 Registered: Sep-04
Wednesday, September 08, 2004 - 23:53 GMT The question doesn't make much sense if you don't say what you'd be using this amp for.
Username: Davids2004 Houston,
TX
Post Number: 743 Registered: Jun-04
Thursday, September 09, 2004 - 14:18 GMT This is what I say. Hook it up and if you like the sound then thats all that matters.
Saturday, September 11, 2004 - 17:23 GMT im trying to push two 12 inch audiobahn subs and my bad its an 1200watt amp
Visitor#78
Saturday, September 11, 2004 - 17:39 GMT You could do better by getting rid of both, and starting over. But at least get rid of the Audiobahn stuff....
Johnathan
Monday, September 13, 2004 - 00:11 GMT audioshite
Username: Allpro Dacula,
Ga
United States
Post Number: 15 Registered: Sep-04
Wednesday, September 15, 2004 - 21:24 GMT Which MA amp is it and which audiobahn subs? Some of the MA Amps are extremely powerful, depends on what your wanting to do. There are a lot of amps that are cleaner though.
