New member Username: UsagalMemphis, Tn Usa Post Number: 1 Registered: Sep-04 | New to the site and need some info on the P5 cards..Please excuse my ignorance but I need a little education here..thought you guys could and would help me out... I have sold alot of these cards without any problems....but have recently ran across a problem with a man in Florida..He bought 20 from me and about 2 weeks later he came back and told me that the first 10 were no good..wanted me to replace them...then about 2 days ago he came back and told me that the other 10 were no good..wants those replaced...Since I don't know anything about them I found this to be very suspicious since i have never had this problem before with any of my other customers.....Is there something that he is getting off of the cards or some way that he is using them and then wants to return them for more...I would appreciate you guys help...Thanks..Lisa |
applebee Unregistered guest | a.- maybe the ones he's returning are not the ones you sold him b.- maybe he cloned them c.- maybe the ones you sold him are not virgin cards and can not be programmed d.- maybe he just likes talking to ypu |
Anonymous | Lisa ...You can ask here....southernbelle4you@hotmail.com |
New member Username: UsagalMemphis, Tn Usa Post Number: 2 Registered: Sep-04 | The cards were new in original wrappers...never opened..never programmed...thanks for your help..I really appreciate it.. |
applebee Unregistered guest | Then they were virgan cards,which are very good to have for ANY of his uses.He's blowing smoke at you.He has no beef with you,unless they are counterfeit and really non working (non programmable,internally damaged,non testable etc),depending upon your source and their origin.There is one file that could help you to check them.Its called P4-D1 card checker UL4S v3.zip.If that file reads the card,then the cards are OK.You only need a HU/P3 card loader/programmer (same ones used to program HU/P3 cards such as a T911 or Mik3 etc) flashed to UL4S. |
