Bronze Member Username: CrappycarguyPost Number: 12 Registered: Sep-04 | Amplifier Type: Mono RMS Power: 350W x 1 @ 4 ohms RMS Power: 700W x 1 @ 2 ohms RMS Power: 1000w x 1 @ 1 ohm The 700 at 2 ohms would be perfect me but I have heard this amp is extremely overrated in its power figures anyone say or know different? Cause if these figures are accurate it would power my perfects perfectly but I need to know now so if these are undereated I can order the bx1500d or if it is accurate to just stick with the bx1000d |
Bronze Member Username: SixstarPost Number: 50 Registered: Aug-04 | Ive only heard a couple say that it isn't rated at the full output. |
Bronze Member Username: CrappycarguyPost Number: 18 Registered: Sep-04 | I have heard that it is really 500 watts at 2 ohms anyone else know anything about this? |
Visitor#78 Unregistered guest | I think that's a line of bull....Hifonics isn't as like boss, profile, and them. It might be slightly under-rated not by half. |
Johnathan Unregistered guest | its 640w @ 2 ohms |
Bronze Member Username: CrappycarguyPost Number: 19 Registered: Sep-04 | how do you know and do you know what the bx1500d is rated at 2 ohms? |
Bronze Member Username: CalisouthernerPost Number: 19 Registered: Jun-04 | No, if I'm not wrong, it' 1000@2ohms 1500@1ohms and 500@4ohms. |
