Hey, I am building up my system and i need some help!!! I want everything to be Ecplise, so i am getting ecplise 2 15" (4ohm+4ohm)titanium subs and a 2 channel class D amp(the DA7232). Will these two match up?? What ohm would i need to set these up to get max power and do you know the power they would be getting??? What is the best combination? I am not sure if i should get this amp or if eclipse makes a smaller one that works better. Well if anyone could help me it would be appreciated.
I'm not the same Jonathan that said "duh", but anyway the titaniums only come in dual 4 ohm, and will run perfectly off that amp. The amp will put 1000W RMS into each sub, don't worry because the Titaniums are underrated and can take 1000W RMS with no problem in my experience with them. Be prepared for an alternator upgrade as any amp will that much power will draw a substantial amount of current.
