Can someone recommend some speaker mounts for the two rear surrounds? I'm trying to purchase some but I'm not sure which ones will fit those speakers appropriately, etc.
Any help would be greatly appreciated. Thanks in advance.
I just used three 2" nails to hand them. There is no screw with small head and long enough body to do the work. I don't see how you can mount them given no place to fasten the speakers to any mounting kit. I checked the stores for mounting kit.
