HELP THIS NEWBIE
mctyndall
I need to prewire my living room this weekend for my surround sound. I can't decide where to place my speakers. Can someone give me some advice on this? Here is a link to my floorplan.
http://www.frankbetz.com/homeplans/plan_info.html?pn=3795&vw=3
The fireplace has moved to the back wall and we do not have the built-ins there. The Entertainment center is gonna go on the "half-wall" right before the kitchen. Any advice?
Username: Jdsaenz1
Post Number: 57
Since the fireplace is not on the same wall as the floorplan shows, have you considered moving the ent. center to that wall? I think that would give you more options if you decide to shift things around in the future, and it also gives your front & rear speakers more space between each other. Seems that things would be a bit crammed and at an awkward angle if you put the ent. center on the little wall by the kitchen...
Let me know.
