Xtant amp problems
i bought a Xtant A3001T amp of ebay and when i go to hook it up the red LED comes on but no sound i have xtant subs to so it should match up i tried the gain and still nothin any suggestions
Username: Insearchofbass
Post Number: 416
what ohm are your subwoofers and how many do you have?
matt_the_great
two 10" 4 ohms xtants
Post Number: 417
that amp can only go bridged mono 4 ohm my bet is you are wired up wrong youd either get 2 ohm or 8 ohm bridge with them
go here to see wiring diagram
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Username: Jmloughrey
Farmington, CT
Post Number: 291
also check your ground....could be bad as well...grounds are a pain
