I have a Boss Audio AVA-650 4 channel 150x4 etc. Its been working for awhile but now the protection light wont go off at all i have tried everything i took the circuit board out and looked at everything nothing is blown. all caps look fine. I have two amps I even tried it on my other connections so i know its not a bad ground, nothing has worked for me so far :[
well my question is, is there anyway to bypass the protection mode ?
yes, get rid of the boss amp, in my opinion they are bad and probably most people on this forum will say that they are bad. I would recomend getting a new amp, not sure what to buy, havent had any four channel amps. My brother had a kicker 4 channel and it pushed some boston acoustics really good, it sounded real clean. But thats just my opinion.
Well if you have 2 amps and you said that you tried the other one on the same connections and i worked then its something wrong with the one amp. I would try to get it fixed- its not worth it. Buy something better.
