hey i dont know much about this stuff but i was planning on buying HiFonics Brutus BX1500D and hookin it up to 2 Infinity Kappa Perfect 12.1 subs but i dont kno if that amp will work with those subs any suggestions? plz help
here are the specs on that amp Amplifier Type: Mono RMS Power: 450W x 1 @ 4 ohms THD at 4-Ohm RMS Power: 0.08% RMS Power: 900W x 1 @ 2 ohms Speaker Level Inputs: No Preamp Outputs: Yes Built-In Crossovers: LP Bass Boost: 0 - 18 dB Frequency Response: 20-250 Hz Signal to Noise Ratio: 90 dB Fuse Rating: 2 x 60 amps
and specs on subs
Size: 12 inch Rec. Sealed Box Dims: 1.00 cu.ft. Rec. Ported Box Dims: 1.75 cu.ft. Free Air Usage: not recommended Sensitivity: 96 dB Frequency Response: 18-150 Hz Recommended RMS Power: 350W Peak Power Handling: 1400W Impedance: 4 ohms subwoofer wiring options
Its gonna give you a little more power then needed but you will be fine. Those specs on the amp are listed at 14.4 volt so it wont be as high as the 900 watts at 2 ohms.
